Wrap text
You can change the shape of text by wrapping paragraph text around an object, artistic text, or a text frame. You can wrap text by using contour or square wrapping styles. The contour wrapping styles follow the curve of the object. The square wrapping styles follow the bounding box of the object. You can also adjust the amount of space between paragraph text and the object or text, and you can remove any previously applied wrapping style.
Text wrapped around an object by using the contour wrapping style
To wrap paragraph text around an object, artistic text, or a text frame
Select the
object or text around which you want to wrap text.
Click
Window
Properties.
In the
Properties docker, click the
Summary button
4
Choose a wrapping style from the
Wrap paragraph text list box.
If you want to change the amount of space between wrapped text and the object or text, change the value in the
Text wrap offset box.
5
Click the
Text tool
, and drag over the object or text to create a
paragraph text frame.
6
Type text in the text frame.
You can wrap existing paragraph text around a selected object by applying a wrapping style to the object and dragging the text frame over the object.
To remove a wrapping style
Select the wrapped text or the object it wraps.
Click
Window
Properties.
In the
Summary button
4
Choose
None from the
Wrap text list box.
