Image palette
The Image palette (Window Color Palettes Image Palette) stores the colors that are used in your image. Every time you use a color in your image, it’s automatically added to the Image palette. However, if you prefer to control which colors are added to the Image palette, you can disable the automatic updates and add colors manually.
When adding colors manually, you can choose colors from a color palette, the image, or a color picker. In addition, you can add colors from an imported image or object.
Drag an object to the Image palette to add colors.
You can clear the Image palette of any unwanted or unused colors by removing colors individually or refreshing the palette to remove all unused colors at once.
When you open an image that was created in a previous version of Corel PHOTO-PAINT, the Image palette does not contain any colors. However, you can easily build the Image palette by adding colors from the entire image, an editable area, or a selected object.
You can also hide the Image palette.
To show or hide the Image palette
Back to Top
• Click Window Color Palettes Image Palette.
The Image palette is located at the bottom of the application window.
Hiding the Image palette does not disable the automatic adding of colors.
To disable the automatic adding of colors to the Image palette
Back to Top
• Control-click a color swatch on the Image palette, and click Palette Auto-Add colors.
To add a color to the Image palette
Back to Top
To
Do the following
Add all colors from an image
Control-click a color swatch on the Image palette, and click Palette Add Colors from Image.
Add a color from an image
Click the arrow in the right corner of the Image palette, click the Eyedropper tool, and click the image.
Add the colors from an object by dragging
Drag the object to the Image palette.
Add colors from an editable area
Define an editable area. Control-click a color swatch on the Image palette, and click Palette Add Colors from Visible.
Add colors from one or multiple objects
Select one or more objects. On the Image palette, Control-click a color swatch, and click Palette Add Colors from Objects.
Colors from PostScript fills are not supported.
You can deselect the Eyedropper tool by pressing Esc.
You can move a color swatch by dragging a color swatch to a new position.
To remove a color from the Image palette
Back to Top
• Control-click a color swatch on the Image palette, and click Delete Color.
To remove all unused colors from the Image palette
Back to Top
• Control-click a color swatch on the Image palette, and click Palette Refresh.
