Open images
You can open most bitmaps in Corel PHOTO-PAINT. Each image you open appears in its own image window.
When you open documents in Corel PHOTO-PAINT, by default they are displayed in tabbed view. You can customize the application so that documents are opened in floating windows.
You can also place images. Placing allows you to add a new image to the active image window. For more information, see Place (import) files.
You can use the clipart and photos that are included with the application. You can search for images by different criteria, such as filename, title, subject, keyword, comment, and other properties attached to the file. For more information, see Find clipart and other images with the Connect Content inspector.
To open an image
Back to Top
1 Click File Open.
2 Locate the folder where the file is stored.
3 Click a filename.
If necessary, you can search for an image by using the search box.
4 Click Open.
To open a file you have recently worked on, click File Open Recent, and click the filename. To clear the list of recently opened files, click File Open Recent Clear Menu.
To open documents in floating windows
Back to Top
1 Click Corel PHOTO-PAINT menu Preferences Corel PHOTO-PAINT.
2 Click General.
3 Enable the Open documents in floating windows check box.
To insert a file into an active image
Back to Top
• Drag the image or sound file to the image window.
You can also open a file in a new image window by dragging the file to the application window.
