Work with special effects
Corel PHOTO-PAINT special effects let you change the appearance of an image. You can apply an effect to the entire image or object, or you can use a mask or a lens to transform only part of an image.
Examples of effects applied to an image. Top (left to right) Original image, Emboss effect, Cubist artistic effect, Mosaic creative effect, Pixelate distort effect; bottom (left to right) Add noise effect, Zoom blur effect, Solarize color transform effect, Edge detect contour effect, Sharpen effect
Effects categories
Effects are organized into the following categories.
Category
Description
3D Effects
Lets you create the illusion of depth. Effects include 3-D rotate, Bevel effect, Cylinder, Emboss, Glass, Page curl, Pinch/punch, Sphere, The Boss, and Zig zag.
Art Strokes
Blur
Lets you blur an image to simulate movement, speckling, or gradual change. Effects include Tune blur, Directional smooth, Feather, Gaussian blur, Jaggy despeckle, Low pass, Motion blur, Radial blur, Smart blur, Bokeh blur, Smooth, Soften, and Zoom.
Camera
Lets you simulate effects produced by various camera lenses. Effects include Colorize, Diffuse, Photo filter, Lens flare, Lighting effects, Sepia toning, Spot filter, and Time machine, which lets you walk your image back through history to recreate some popular photographic styles from the past.
Color Transform
Lets you create photographic illusions by using color reduction and replacements. Effects include Bit planes, Halftone, Psychedelic, and Solarize.
Contour
Lets you highlight and enhance the edges of an image. Effects include Edge detect, Find edges, Trace contour, and Local Equalization.
Creative
Lets you apply various textures and shapes to an image. Effects include Art Style, Crystalize, Fabric, Frame, Glass block, Mosaic, Scatter, Smoked glass, Stained glass, Vignette, and Vortex.
Custom
Lets you apply a wide range of effects to your image. For example, you can add texture and patterns to an image (Bump-map effect). Effects include Band pass, Bump map, and User defined.
Distort
Lets you distort image surfaces. Effects include Blocks, Displace, Mesh warp, Offset, Pixelate, Ripple, Shear, Swirl, Tile, Wet paint, Whirlpool, and Wind.
Noise
Lets you modify the graininess of an image. Effects include Tune noise, Add noise, 3-D stereo noise, Maximum, Median, Minimum, Remove Moire, and Remove Noise.
Sharpen
Lets you add a sharpening effect to focus on and enhance edges. Effects include Adaptive unsharp, Directional sharpen, High pass, Sharpen, and Unsharp mask.
Texture
Lets you add texture to an image by simulating a variety of surfaces, such as cobblestone, elephant skin, plastic, and relief sculpture. Effects include Brick wall, Bubbles, Canvas, Cobblestone, Elephant skin, Etching, Plastic, Plaster wall, Relief sculpture, Screen door, Stone, and Underpainting.
Plug-ins
Lets you use a third-party filter to apply effects to bitmaps in Corel PHOTO-PAINT. An installed plug-in appears at the bottom of the Effects menu.
Some effects support only RGB images. If an image is in a color mode that is not supported, the application converts the image to the RGB (24-bit) mode.
To browse the effects that are available in the application, see Special effects categories.
Non-destructive editing
Corel PHOTO-PAINT lets you apply effects non-destructively. When you apply an effect non-destructively, the original image is not affected; Corel PHOTO-PAINT saves the changes separately, so you can edit, remove, show or hide them, and revert to the original object or image at any point. You can apply effects from the Effects menu, the Effects docker (Window Dockers Effects), or the Add Effect button in the Objects docker (Window Dockers Objects).
Customizing effects
Before you apply an effect, you can customize it. For example, when you use a vignette effect to frame an image, you can increase the offset value and decrease the fade value to decrease the size and opacity of the frame. With a watercolor effect, you can decrease the size of the brush to show more image detail or increase the size of the brush for an abstract effect.
All effects dialog boxes have a preview window that allows you to preview your designs in real-time as you adjust the special effect settings. You can pan to a new area, zoom in or out, and choose how to display the artwork in the preview window, so you can evaluate the adjustments you make. By default, the application also shows a live preview of the image in the drawing window as you modify the effect settings.
The before and after full (top) and split (bottom) previews are particularly useful to keep track of edits and understand how different settings affect the image.
The Effects docker is the hub for non-destructive editing, allowing for quick adjustments and unlimited experimentation. You can show and hide effects, edit applied effects, and apply multiple special effects to the same object. Plus, you can change the order of the applied special effects, and you can delete a special effect. Effects are cumulative; each time you apply an effect, it’s stacked on top of the previous effect. In the Effects docker, the effects appear in the order in which you apply them, with the most recently added effect at the top of the list. You can change the area to which an effect is applied by creating a mask and applying the adjustment to the newly defined editable area. In addition, you can create a mask from the areas affected by an effect so that you can re-use it when applying other effects. You can also flatten effects to apply changes permanently.
Applying special effects to an image area
You can apply a special effect to part of an image by defining an editable area. For information about editable areas, see Masks.
You can also use a lens to apply a special effect to part of an image. When you use a lens, changes are not applied to the image; instead, they are seen on the screen through the lens. Most special effects are also available as lenses. Applying a non-destructive effect to an object affects only the appearance of the selected object, whereas applying an effect to a lens affects the appearance of all objects beneath the lens. For information about lenses, see Create lenses.
Repeating and fading special effects
After you apply an effect destructively, you can repeat it to intensify its result or fade it to diminish its intensity. For more information about repeating and fading actions, see Undo, redo, repeat, and fade actions.
With non-destructive editing, you cannot apply the same effect twice to an object.
Using merge modes
You can define how an effect is merged with the image. For information about merge modes, see Merge modes.
Tracking, recording, and automating special-effects operations
Corel PHOTO-PAINT lets you track, record, and automate special-effects operations. For more information, see Use macros and scripts to automate tasks.
To apply an effect destructively
Back to Top
1 Do one of the following:
Open an image — to apply an effect to an image
Define an editable area — to apply an effect to an image area
Select an object — to apply an effect to an object
2 Click Effects, choose a special effect category, and click an effect.
3 Adjust the settings of the special effect filter.
If the image contains one or more objects, the special effect is applied only to the background or the selected object.
By default, as you modify the effect settings, the application shows a representation of the adjusted image in the image window. To disable the live preview, disable the Preview check box.
Some special effects can affect the shape of the object they are applied to. You can retain an outline of the object’s original shape by enabling the Lock transparency button on the Objects docker. The areas that remain between the outline of the original shape and the new shape of the object are filled with black. If the Objects docker is not open, click Window Dockers Objects.
To apply an effect non-destructively
Back to Top
Select the background — to apply an effect to the background layer
2 Click Window Dockers Effects.
3 Click the Add effect button , choose a special effect category, and click an effect.
4 Adjust the settings of the special effect filter.
You cannot apply the same non-destructive effect twice to an object.
When you add a non-destructive effect, the Show/Hide Effects icon appears beside the object name in the Objects docker.
You can also apply an effect non-destructively by clicking the Add Effect button in the Objects docker (Window Dockers Objects), choosing an effect category, and clicking an effect.
Some special effects can affect the shape of the object they are applied to. You can retain an outline of the object’s original shape by enabling the Lock object transparency button on the Objects docker. The areas that remain between the outline of the original shape and the new shape of the object are filled with black. If the Objects docker is not open, click Window Dockers Objects.
To preview your design while adjusting the effect settings
Back to Top
1 Click the Preview button in the special effect dialog box.
2 Perform a task from the following table.
To
Do the following
Pan to another area of the image
Using the Pan tool , drag the image until the area you want to see is visible.
Zoom in and out
Using the Zoom in tool or the Zoom out tool , click in the preview window.
Fit the image in the preview window
Click the Zoom to fit button.
View the resulting image in a single pane
Click the Full preview button .
View the original and resulting image in separate panes
Click the Before and after full preview button .
View the original and resulting image in a single pane
Click the Before and after split preview button , and drag the split view divider in the center of the window to the left or right.
To work with non-destructive effects
Back to Top
1 Select an object that has a non-destructive effect applied.
2 Open the Effects docker (Window Dockers Effects).
3 Perform a task from the following table.
To
Do the following
Show or hide an effect
Click the Show/Hide icon for the effect you want to show or hide.
Tip: To show or hide multiple effects, select the effects, and click the Show/Hide icon .
Apply additional effects
Click the Add effect button and choose an effect from the menu.
Edit an applied effect
Select an effect and click the Edit icon .
Change the order of applied effects
Click an effect and drag it to a new position in the list.
Delete an effect
Select an effect and click the Delete button .
Change the area to which an effect is applied
Using a mask tool, define an editable area to which you want to apply the adjustment. Right-click the effect in Effects docker, and click Apply to Mask.
Create a mask from the areas to which an effect is applied
Right-click the effect in Effects docker, and click Create Mask from Effect.
Flatten effects to apply changes permanently
Click the Flatten effects button .
Note: When multiple objects with special effects are selected, clicking the button will flatten the effects only in the first selected object.
Clicking the Show/Hide icon in the Effects docker changes the visibility of individual effects, whereas clicking the Show/Hide Effects icon in the Objects docker changes the visibility of all effects applied to an object and overrides the visibility settings for individual effects that you may have set in the Effects docker.
You can also hide and show effects by clicking the Show/Hide Effects toggle icon in the Objects docker (Window Dockers Objects). To hide or show the effects of multiple objects, select the objects, and click the Show/Hide Effects toggle icon . You can hide and show the effects for locked objects.
To repeat the last applied destructive effect
Back to Top
Click Effects Repeat, and click one of the following:
Repeat [last effect] — applies the last applied effect
[Last effect] to all visible — applies the last applied effect to all visible elements in an image
[Last effect] to all selected — applies the last applied effect to all selected objects in an image
