Increasing or decreasing the number of nodes on a path lets you change the shape of the line and curve segments with greater control.
Adding and deleting nodes
You can add nodes to a path if the existing segments, nodes, and control points do not let you shape a path the way you want. You can add one node at a time or several at once. When you add a node, you can choose where it displays on the line segment.
When you delete nodes, the shape of the path can change, depending on the position of the nodes that are removed.
Smoothing paths
Paths you create from masks or draw freehand style can contain more nodes than required to maintain their shape. These extra nodes can give paths a rough appearance. You can smooth the path by removing the extra nodes from the entire path or from a section of the path.
| 2 . |
Click the Shape button on the property bar. |
You can add a node at the midpoint of a path segment by selecting a node and clicking the Add node button on the property bar. The node is added between the selected node and the node that precedes it in the path.
You can also add a node by double-clicking where you want to add the node to a path segment.
| 2 . |
You can also delete a node by double-clicking it.
| 2 . |
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
