You can change the spacing between lines of text, which is also known as "leading" or "interline spacing." When changing the line spacing for artistic text, it applies only to the lines of text that are separated by a hard return.
You can change the spacing between characters (also known as "letter spacing") in a block of text. For example, fully justifying a block of text may insert too much space between characters, which creates a visual imbalance. To improve readability, you can decrease the character spacing. You can also adjust the spacing between words.
| 2 . |
Click Object Text Text properties. |
| 3 . |
In the Text properties docker, choose one of the following unit of measurement options from the Vertical spacing units list box: |
% of Char. height — lets you use a percentage value that is relative to the character height |
Points — lets you use points |
% of Pt.size — lets you use a percentage value that is relative to the character point size |
| 2 . |
| 3 . |
In the Text properties docker, type a value in the Character spacing box. |
| 2 . |
| 3 . |
In the Text properties docker, type a value in the Word spacing box. |
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
