| • | To apply a bitmap pattern fill |
| • | To modify a bitmap pattern fill |
| • | To create a bitmap pattern fill from an imported image |
Bitmap fills are bitmaps that you can use to fill an object or image. You can fill an area with a single bitmap. You can also tile, or repeat, a small bitmap across an area to create a seamless pattern.
Examples of bitmap pattern fills
It is best to use less complex bitmaps for fills, because complex bitmaps are memory-intensive and slow to display. The complexity of a bitmap is determined by its size, resolution, and bit depth.
Corel PHOTO-PAINT provides a collection of bitmap patterns that you can access. You can browse the available patterns, search patterns by keyword, mark patterns as favorites, and sort them. For more information, see Finding and viewing fills and transparencies.
After you create a new pattern, you can save it for future use. For more information, see Saving fills and transparencies.
Bitmap fills can be used to create interesting backgrounds and textures.
| 1 . | In the toolbox, click the Fill tool |
| If you want to fill an object, you must select it by using the Object pick tool |
| 2 . | Click the Bitmap pattern fill button |
| 3 . | Open the Fill picker on the property bar, and double-click a fill thumbnail. |
| 4 . | Click where you want to apply the fill in the image. |
Merge modes control the way the foreground or fill color blends with the base color of the image. You can change the merge mode setting from the default (Normal) for specific blending purposes. For more information about merge modes, see Understanding merge modes.
For information about how to find fills, see To find, filter, and sort fills and transparencies.
| 3 . | Click the Edit fill button |
| 4 . | In the Edit fill dialog box, open the Fill picker, and click a fill. |
| 5 . | Perform an action from the following table. |
Enable the Edge match check box, and move the slider.
Enable the Brightness check box, and move the slider.
Enable the Luminance check box, and move the slider.
Enable the Color check box, and move the slider.
Type values in the Fill width and Fill height boxes.
Type values in the X and Y boxes.
Type a value in the Skew box or the Rotate box.
| 4 . | In the Edit fill dialog box, click the New source from file button. |
| 5 . | In the Import dialog box, locate the image that you want to use, and double-click the filename. |
The new bitmap fill appears in the Fill picker.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
