Fountain fills gradually change from one color to the next, along a linear, elliptical, conical, or rectangular path. You can use fountain fills to create the illusion of depth. Fountain fills are also known as gradient fills.
Linear, elliptical, conical, and rectangular fountain fills
Corel PHOTO-PAINT provides a collection of fountain fills that you can access. You can browse the available fountain fills, search by keyword, mark fills as favorites, and sort fills. For more information, see Finding and viewing fills and transparencies.
Any fountain fill can be modified to suit your needs, and you can create your own fills from scratch. Fountain fills can contain two or more colors, which you can position anywhere in the fill’s progression. You can specify fill attributes such as the direction of a fill’s color blend, the fill’s angle, center point, and midpoint. You can also resize, smooth, skew, mirror, or repeat a fill.
Left to right: An object with a linear fountain fill applied. Another color is added to the fill. The fill is resized to 50% of the object width and height, and then repeated and mirrored. Last, the fill is rotated 45 degrees.
After you create a fountain fill, you can save it for future use. For more information, see Saving fills and transparencies.
You can also apply a fountain fill interactively by using the Interactive fill tool. A gradient arrow, which marks the transition from one color to another, appears in the image window. Each color in the fountain fill is represented by a square node on the gradient arrow. You can change and add colors or adjust the transparency of individual colors. You can also adjust the size and direction of the fountain fill in the image window.
| 2 . |
Click the Fountain fill button on the property bar. |
| 3 . |
Open the Fill picker on the property bar, and double-click a fill thumbnail. |
Merge modes control the way the foreground or fill color blends with the base color of the image. You can change the merge mode setting from the default (Normal) for specific blending purposes. For more information about merge modes, see Understanding merge modes.
For information about how to find fills, see To find, filter, and sort fills and transparencies.
| 2 . |
| 3 . |
Click the Edit fill button on the property bar. |
| 4 . |
In the Edit fill dialog box, click one of the following buttons to choose a fountain fill type: |
Fountain fills can contain up to 99 colors.
You can change the color of a node by clicking the node and clicking a color on the color palette.
If you want to fill an object, you must select it by using the Object pick tool before applying the fill, and then click the Lock object transparency button in the Object manager docker to protect the object’s shape and transparency. |
You can also create a mask to constrain the fountain fill to a portion of the image. For more information, see Working with masks.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
