Applying fountain transparency
Fountain transparency makes the object fade from one transparency value to another. The fountain transparency can be linear, elliptical, conical, or rectangular.
A linear fountain transparency was applied to the text.
The application provides a collection of fountain transparencies that you can access. You can browse the available fountain transparencies, search by keyword, mark fills as favorites, and sort fills. You can also download additional fill packs, which can be used as transparencies. For more information, see Finding and viewing fills and transparencies.
You can create your own fountain transparency by adding and removing nodes, and specifying a transparency value for each node. You can also reverse, mirror, resize, or skew a fountain transparency, or apply other transformations.
After you create or edit a fountain transparency, you can save it for future use. For more information, see Saving fills and transparencies.
To apply a fountain transparency Back to Top
For information about how to find transparencies in the Transparency picker, see To find, filter, and sort fills and transparencies.
To create a fountain transparency Back to Top
Click the Default transparency button .
Click the Set to default button  to unlock the fountain steps, and type a value in the Fountain steps box.
Move the Acceleration slider.
Click the Smooth button .
Type values in the Transparency width and Transparency height boxes.
Type values in the X and Y boxes.
Enable the Free scale and skew check box.
To save the transparency, click the Save as new button .
You can also drag colors, which are converted to grayscale, from the color palette onto the object’s transparency nodes .
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
