| • | To apply a texture transparency |
A texture transparency is applied to the object filled with light green.
| 1 . | Select an object. |
| 2 . | In the toolbox, click the Object transparency tool |
| 3 . | On the property bar, click the Texture transparency button |
| 4 . | On the property bar, click the Edit transparency button |
| 5 . | In the Edit transparency dialog box, choose a texture library from the Texture library list box. |
| 6 . | Choose a texture from the Fill picker. |
| 7 . | Perform an action from the following table. |
Move the Foreground transparency slider.
Move the Background transparency slider.
Click Randomize. Each time the button is clicked, random changes are made to unlocked parameters, and the modified texture is displayed in the Preview window.
Click Transformations, and click the Mirror tiles horizontally
Click Transformations, and type values in the Transparency width and Transparency height boxes.
Click Transformations, and type values in the X and Y boxes.
Click Transformations, and type a value in the Rotate box.
Click Transformations, and type a value in the Skew box.
Click Transformations, and click the Row offset
Click Options, and type a value in the Bitmap resolution box.
Click the Save texture button
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
