| • | To import a Corel Painter file |
| • | Corel Painter (RIF) technical notes |
Imported Corel Painter (RIF) files retain information such as floating objects, which makes the files much larger than GIF or JPEG files. Corel Painter files can be imported for resizing and adjusting floaters.
| 1 . | Click File |
| The File |
| 2 . | Locate the folder in which the file is stored. |
| 3 . | Choose RIFF - Painter (*.rif) from the list box next to the File name box. |
| 4 . | Click the filename. |
| 5 . | Click Import. |
| 6 . | Click the image window. |
| • | The embedded color profile is preserved, but can be changed after importing the file. |
| • | If the Corel Painter image contains a transparent background, which is called a canvas in Corel Painter, it is preserved. |
| • | Vector shapes are not preserved in the imported file. |
| • | Text and annotations are not preserved. |
| • | Bitmap layers are imported as objects. |
| • | Layer masks are retained as clip masks. |
| • | Liquid Ink, Watercolor, Digital Watercolor, and plug-in layers are imported as RGB objects. |
| • | Mosaics and tessellations are imported as RGB objects. |
| • | Image slicing is not retained. |
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
