Creating custom brushes
You can create a custom brush by modifying brush attributes. Once you have created a custom brush, you can save it and use it again.
Nib properties
The shape of a brush is determined by the brush nib. The preset nib shapes can be modified or a nib can be created from an editable area and saved. The nib attributes you can adjust are
Stroke attributes
The stroke attributes you can modify are
Dab attributes
The dab attributes you can adjust are
Brush texture
Loading a preset brush texture gives you additional design options. The texture attributes you can adjust are
Color variation
The color attributes you can modify are
To create a custom brush Back to Top
Click the Nib options button on the Nib properties bar, and click Add current nib.
Click the flyout arrow on the Brush settings docker, and click Save brush. In the Save brush dialog box, type a filename.
To create a brush nib from an editable area Back to Top
To load a preset brush texture Back to Top
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
