Displaying and arranging objects
You can hide an object from view and change the stacking order of objects.
Displaying and hiding objects
By default, all objects are displayed in the image window. However, you can hide an object to make it temporarily invisible.
Changing the order of objects
When you create multiple objects in an image, they are stacked on top of one another in the order in which they were created. The most recently created object is at the top of the stack, and the image background is at the bottom. You can move an object in the image window to cover an object that is lower in the stacking order; however, an object always displays behind objects that are higher in the stacking order. Changing the stacking order of objects brings hidden objects into view or places the topmost objects behind other objects.
Changing the stacking order places the bike behind the boxes.
To hide or display an object Back to Top
When an object is hidden, the Hide/Show icon is not displayed.
When you hide the background, a checkered transparency grid displays. To customize the transparency grid, click Tools Options. In the Workspace list of categories, click Display. In the Display dialog box, modify any attributes in the Transparency grid area.
To change the order of objects Back to Top
The image background is always placed at the bottom of the stacking order and no object can be placed below it.
When objects are grouped, they are considered to be at the same level in the stacking order. Therefore, you cannot place an object between individual objects in a group.
You can change the stacking order of an object by dragging its thumbnail to a new position in the Object manager docker. If the Object manager docker is not open, click Window Dockers Object manager.
You can also change the order of objects using shortcut keys. Move an object to the top of the stack by pressing Shift + Page up; move it to the bottom of the stack, but above the background, by pressing Shift + Page down; move it up one step in the stacking order by pressing Ctrl + Page up; and move it down one step by pressing Ctrl + Page down.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
