| • | To add to or subtract from an editable area |
| • | To remove protected areas from an editable area |
| • | To expand or contract an editable area |
| • | To add adjacent pixels of similar color to an editable area |
You can add parts to and remove parts from an editable area.
By default, each editable area that you define replaces the last one defined. However, you can use the following mask modes if you want to retain the current editable area but modify its shape:
The Ellipse mask tool is used in the Normal mode. |
The entire ball is defined as an editable area in the resulting mask. |
The Ellipse mask and Freehand mask tools are used in the Subtractive mode. |
The resulting editable area consists of the yellow areas of the ball. |
The Magic wand mask tool is used in the Additive mode. |
The Ellipse mask tool is used in the Overlap mode. |
You can remove protected areas from within an editable area. This feature is useful for modifying color masks that have large editable areas.
You can expand and contract an editable area by a specific number of pixels. The pixels are added to or removed from the edge of the editable area.
Adding pixels of similar color
You can add adjacent pixels of a similar color to an editable area. The editable area expands until it reaches pixels with colors that are too dissimilar from the colors in the original editable area. The color tolerance value you specify sets the percentage of color variation allowed between the pixels in the original editable area and the adjacent protected areas.
| 1 . | In the toolbox, click a mask tool. |
| 2 . | On the property bar, click one of the following buttons: |
| • | Additive |
| • | Subtractive |
| • | Overlap |
| 3 . | Drag in the image to define the area that you want to add to, or subtract from, an editable area. |
After you begin to drag, you can use Ctrl and Shift to constrain the shape of the area you add or subtract. For example, if you’re using the Ellipse mask tool, holding down Ctrl constrains the shape to a circle, and holding down Ctrl + Shift makes the circle expand from the center.
| • | Click Mask |
| 1 . | In the toolbox, click the Magic wand mask tool |
| 2 . | Type a value in the Tolerance box on the property bar. |
| 3 . | Click Mask |
| • | Grow — expands an editable area to include all similarly colored adjacent pixels |
| • | Similar — expands an editable area to include all similarly colored pixels in the entire image |
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
