Grouping and combining objects
You can group objects so they behave as one unit. Grouped objects can be moved, deleted, or transformed as a single entity. Even hidden objects in a group are transformed together with the visible objects.
You can add objects to, or remove objects from, an existing group. You can also nest a group of objects, which allows you to group objects within an existing group. You can also ungroup the objects when you want to edit them individually.
Grouped objects can be moved or transformed together. In this example, the ball and the boxes are grouped and resized as a group.
Combining objects lets you group them permanently. You can combine multiple objects into one object, or combine objects with the background. When you combine objects, you lose the ability to edit the objects independently. You can also decrease the file size of an image by combining objects.
To group objects Back to Top
You can also group objects in the Object manager docker by holding down Ctrl, selecting the objects that you want to group, and clicking the New group button .
To add an object to a group Back to Top
You can also add an object to an existing group in the Object manager docker by selecting the object and dragging it to the group.
To remove an object from a group of objects Back to Top
To nest a group of objects Back to Top
To ungroup objects Back to Top
To combine objects Back to Top
Select the objects, and click Object Combine Combine objects together.
Select an object or objects, and click Object Combine Combine objects with background.
Click Object Combine Combine all objects with background.
When objects are combined with the background, they become part of the background layer and can no longer be edited as individual objects.
You can also combine objects in the Object manager docker by holding down Ctrl, selecting the objects that you want to combine, and clicking the Combine selected objects button .
You can specify a merge mode and transparency level before you combine objects by modifying the settings in the Merge mode list box and Opacity box in the Object manager docker. If the Object manager docker is not open, click Window Dockers Object manager.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
