JPEG 2000 (JP2)
The JPEG 2000 (JP2) file format is a JPEG image with advanced compression and file data capabilities. JPEG 2000 standard files can store more descriptive file data (or metadata), such as dimensions, tone scale, color space, and intellectual property rights, than JPEG 2000 codestream files. Codestream files are optimized for network transmission since they resist bit errors that can cause data loss on low-bandwidth channels.
Not all web browsers support JPEG 2000 formats. You may require a plug-in to view these files.
You can mask an area of a JP2 image to define a region of interest (ROI). If you apply a lower compression setting to the ROI, you can improve the image quality of the area.
When you export the image to a JP2 file, you can choose to view download progression by resolution, quality, and position.
To import a JPEG 2000 file Back to Top
To export a JPEG 2000 bitmap Back to Top
In the Settings area, choose a color mode from the Color mode list box.
In the Advanced area, enable the Embed color profile check box.
In the Settings area, choose a quality option from the Quality list box or type a value.
In the Advanced area, choose Resolution\Quality from the Progression list box.
In the Advanced area, choose Resolution\Position from the Progression list box.
In the Advanced area, choose Position from the Progression list box.
In the Advanced area, choose Channels from the Progression list box.
In the Advanced area, enable the Codestream check box.
JPEG 2000 (JP2) technical notes Back to Top
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
