JPEG is a standard format developed by the Joint Photographic Experts Group. Through the use of superior compression techniques, this format allows the transfer of files among a wide variety of platforms. JPEG supports 8-bit grayscale, 24-bit RGB, and 32-bit CMYK color modes.
The JPEG format is commonly used on the web. For more information, see Choosing a web-compatible file format.
The File Import command lets you place the file as an object in the active image. If you want to open a JPEG file as an image, click File Open. |
| 3 . |
Choose JPG - JPEG Bitmaps (*.jpg; *.jtf; *.jff; *.jpeg) from the list box next to the File name box. |
You can drag on the image window to resize the image.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
