Moving and aligning editable areas
You can move an editable area anywhere in an image with or without the image pixels it encloses. When an editable area and the image pixels it encloses are moved together, the pixels can be cut from the image and the hole filled with background color, or the pixels can be copied by floating the editable area.
You can align an editable area to one or more selected objects. You can also align an editable area to the center or the edges of an image. Depending on where you want an editable area to appear, you can experiment with horizontal and vertical alignment options.
An editable area can also be aligned to guidelines and to the grid. For more information, see Using the guidelines, grid, and rulers.
To move an editable area Back to Top
You can also move an editable area by nudging it.
To move an editable area and its image pixels Back to Top
When an editable area is moved once, the underlying image is replaced with the background color. If the same editable area is moved again, the underlying image is no longer replaced with the background color.
You can leave a copy of an editable area you move by holding down Alt as you drag.
To align an editable area with an object Back to Top
To align an editable area with the edges or center of an image Back to Top
When you align an editable area to the edges or center of an image with the Align to grid check box enabled, the editable area is aligned to the gridlines nearest to the specified edges or center of the image.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
