Moving, copying, and deleting objects
Corel PHOTO-PAINT lets you move an object or part of an object to a new location in the same image window or to another image window. You can also copy an object, or part of an object, and paste it into an image. To copy and paste between image windows, you can drag and drop an object from one window to another.
When you move or copy part of an image, you must first define an editable area for that part of the image. You can also move or copy an object into an editable area. For more information about defining editable areas, see Defining editable areas.
When you no longer need an object, you can delete it.
The selected photo object is moved from the top-left corner to the lower-right corner.
To move an object Back to Top
Select an object. Click the Position and size button on the property bar, type values in the Position boxes, and click Apply.
For information about setting the nudge value, see Setting options.
To move part of an object Back to Top
To copy an object Back to Top
If you paste the object into the same window, the copy is placed on top of the original object.
You can also copy and paste an object using Ctrl + C to copy and Ctrl + V to paste.
To copy a selected object within the same image window, click Object Duplicate.
To copy or move an object into an editable area Back to Top
To delete an object Back to Top
You can also delete a selected object by clicking the Delete button in the Object manager docker. If the Object manager docker is not open, click Window Dockers Object manager.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
