Painting symmetrical patterns and orbits
Corel PHOTO-PAINT gives you tools to create symmetrical and orbital patterns.
You can paint symmetrical patterns on an image by using the radial or mirror brush symmetry mode. When you paint in radial mode, satellite brush nibs, called satellite points, create brushstrokes around a center point. When you paint in mirror mode, an identical brushstroke is created on the horizontal plane, the vertical plane, or both.
Painting with orbits
You can create spiral effects by painting an image with orbits. Orbits are circular paths that rotate around a center point. Orbits let you paint spirals, pods, and rings. For example, you can draw a single spiral and adjust the size and closeness of the coils. You can also vary the size of the coils to create rounded segments called pods, or increase the number of orbits to create rings.
To paint symmetrical patterns Back to Top
Click the No symmetry button on the Symmetry bar to disable the brush symmetry mode.
To paint with orbits Back to Top
You can hide or display the point around which the orbits rotate clicking the Include center button on the Orbits bar in the Brush settings docker.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
