As you create or edit an image, you can revert to its last-saved version to remove all the changes you made since you saved the image. If you want to remove only some changes, you can restore specific image areas to the way they look in the last-saved version of the image.
You can also create a checkpoint to save the current image temporarily, so that later you can return the image to that state if necessary.
You can also create a workspace that lets you save automatically using a checkpoint. For more information, see To specify auto-save settings.
Click File Revert to saved. |
You can also revert to the last saved image by clicking the Revert to last saved button
in the Undo manager docker.
If you are creating an image from scratch, you must save it before using the Clone from saved tool. For more information about saving images, see Saving and closing.
Click Edit Checkpoint.
Click Edit Restore to checkpoint.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
