Selecting objects
You must select objects before you can change them. You can select one object, covered objects, multiple objects, all objects, or multiple groups of objects. When you select a single object, a highlighting box with eight transformation handles surrounds the object. When you select multiple objects, the highlighting box expands to surround all of the objects.
You can select multiple objects, but only one object is active. The active object is outlined by a dashed outline called a marquee. You can edit the active object by filling it and applying special effects to it.
When you finish making changes to the selected objects, you can deselect them.
One object is selected in the image on the left. On the right, the highlighting box indicates that both objects are selected. The object marquee appears around the lizard, which is the active object.
To select objects Back to Top
In the toolbox, click the Object pick tool , and click an object.
Click Objects Select all objects.
In the toolbox, click the Object pick tool . Hold down Alt, and click until the highlighting box of a covered object is displayed. This shortcut key allows you to cycle through layered objects.
In the toolbox, click the Object pick tool . Click one object, hold down Shift, and click the other objects.
In the toolbox, click the Object pick tool . Click an object in one group, hold down Shift, and click an object from each group that you want to select.
When the Show object marquee command in the Object menu is enabled, a dashed outline, called a marquee, surrounds the active object.
If the background is selected before you click Objects Select all objects, it is added to the selection — all objects and the background are now selected. If an object is selected before you click Objects Select all objects, the background is not included in the selection.
You can select an object by clicking a thumbnail in the Object manager docker. If the Object manager docker is not open, click Window Dockers Object manager.
You can also select objects in the Object manager docker stacking order using the following shortcut keys: press Shift + N to select the object above the current object; Shift + P to select the object below the current object; Shift + T to select the top object in the stacking order; and Shift + B to select the background object or the bottom object in the stacking order.
To deselect objects Back to Top
In the toolbox, click the Object pick tool . Click anywhere outside the object’s highlighting box.
Click the Object pick tool , hold down Shift, and click each object in the image window that you want to deselect.
Click the Object pick tool , and click the background.
When you deselect an active object, it is still active.
If the background is part of the selection, clicking the background in the image window does not deselect all objects.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
