Spraying images
You can paint with small-scale, full-color bitmaps, instead of a brush. For example, you can enhance landscapes by spraying clouds across the sky or foliage across the ground.
Corel PHOTO-PAINT includes a variety of images, which are used to create spraylists. You can load a preset spraylist, edit a preset, or create a spraylist by saving images in an image list. You can edit the source images at any time.
Corel Content provides an online collection of image lists that you can access and search. When you find an image list that you like, you can download it and use it.
For more information about accessing image lists, see Accessing content.
In this example, butterflies have been sprayed around the rose.
To spray images Back to Top
Choose an option from the Image sequence list box on the property bar.
Type a value in the Transparency box on the property bar.
To adjust the brushstroke transparency interactively, hold down Alt, and click in the image window without releasing the mouse button to display a transparency slider.
Type a value in the Images per dab box on the property bar.
Type a value in the Image spacing box on the property bar.
Type a value in the Spread box on the property bar.
Type a value in the Fade out box on the property bar. Negative numbers fade in while positive numbers fade out.
The minimum and maximum numeric values for a box on the property bar can be displayed by right-clicking in the box to open the Settings dialog box.
To load an image list Back to Top
To create a spraylist Back to Top
To create an image list from an object Back to Top
To create an image list from an image Back to Top
To edit a source image Back to Top
After you edit an image list, you must reload it in the Image sprayer tool to activate the changes.
To access and use an online image list Back to Top
Type a search term in the Search box, and press Enter.
Click the Home button .
Watermarked image lists cannot be downloaded. Content appears watermarked if you have not signed in or do not have the required membership. To sign in, click the Sign in button in the upper-right corner of the dialog box.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
