You can change the form of an editable area of a mask by rotating, scaling, sizing, flipping, skewing, distorting, or applying perspective to it. If an editable area is floating above the image, it is automatically merged with the underlying image when it is transformed.
| To rotate an editable area |
| 1 . | In the toolbox, click the Mask transform tool |
| 2 . | Click the Rotate button |
| If you want to change the center of rotation of the editable area, drag the center of rotation to a new position within the editable area. |
| 3 . | Drag a corner handle of the mask marquee. |
| 4 . | Double-click in the editable area. |
You can rotate an editable area by a specific angle by typing a value in the Angle of rotation box on the property bar and clicking Apply.
You can change the center of rotation, also known as a pivot point, by typing values in the Center of rotation boxes on the property bar and clicking Apply.
| To scale an editable area |
| 2 . | Click the Scale button on the property bar. |
On the property bar, type percentage values in the Scale boxes and click Apply.
Hold down Shift as you drag a corner handle.
| To size an editable area |
| 2 . | Click the Position and size button |
| 3 . | Drag a middle handle of the mask marquee. |
| If you want to size the editable area proportionally, drag a corner handle of the mask marquee. |
On the property bar, type values in the Size boxes and click Apply.
Hold down Shift as you drag a center transformation handle. The change in size occurs in two opposite directions.
Hold down Ctrl as you drag a transformation handle.
| To flip an editable area |
| 3 . | Drag a center handle of the mask marquee across the editable area and past the opposite center handle. |
You can flip an editable area symmetrically by holding down Ctrl and dragging a middle handle across the editable area and past the opposite middle handle.
| To skew an editable area |
| 2 . | Click the Skew button |
You can also skew an editable area by typing values in the Skew angle boxes on the property bar and clicking Apply.
Before applying the transformation, you can return an editable area to its original size by pressing Esc.
| To distort an editable area |
| 2 . | Click the Distort button |
| 3 . | Drag a transformation handle of the mask marquee. |
You can also set the Mask transform tool to the Distort mode by clicking in the editable area until the handles you can use to distort the editable area appear.
| To apply perspective to an editable area |
| 2 . | Click the Perspective button |
You can also set the Mask transform tool to the Perspective mode by clicking in the editable area until the transformation handles appear.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
