You can create interesting effects by blending objects with other objects that are below them in the stacking order, or by blending objects with the background. As you experiment with settings, the transparency effect previews in the image window.
| 2 . |
In the Object properties dialog box, click the General tab. |
| 4 . |
On the Active object graph and the Composite underlying graph, drag any of the following nodes: |
Increasing minimum (lower-left node) — specifies the upper minimum grayscale value of the pixels in the object |
Decreasing maximum (upper-right node) — specifies the lower maximum grayscale value of the pixels in the object |
Decreasing minimum (lower-right node) — specifies the lower minimum grayscale value of the pixels in the object |
The boxes to the right of the Blend list box display the grayscale and transparency values of the selected object’s pixels.
You can specify the grayscale values of pixels on a scale of 0 (black) to 255 (white), and the opacity of pixels on a scale of 0 (transparent) to 100 (opaque). Pixels in the active object that fall outside the specified range are hidden, so the pixels of the underlying object are visible.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
