Using the Image palette
When you start a new image, an empty color palette, named the Image palette, appears docked in the lower-left corner of the image window. Every time you use a color in your image, it’s automatically added to the Image palette. However, if you prefer to control which colors are added to the Image palette, you can disable the automatic updates and add colors manually.
You can add colors from a color palette, an external image, a color picker, or a color-related dialog box, such as the Uniform fill color dialog boxes. In addition, you can add colors from an imported image or object.
Drag an image or object to the Image palette to add colors.
You can clear the Image palette of any unwanted or unused colors by removing colors individually or resetting the palette to remove all unused colors at once.
When you open an image that was created in a previous version of Corel PHOTO-PAINT, the Image palette does not contain any colors. However, you can easily build the Image palette by adding colors from the entire image, an editable area, or a selected object.
You can also hide the Image palette.
To disable the automatic adding of color to the Image palette Back to Top
You can also disable the automatic adding of color by clicking Tools Options, clicking Color palette in the Customization list of categories, and then disabling the Automatically update the image palette check box.
To add a color to the Image palette Back to Top
In the Image palette, click the Eyedropper tool, hold down Ctrl, and click the image until you add the colors that you want.
Define an editable area. In the top left corner of the Image palette, click the flyout button, and click Add colors from visible.
When dragging an image to the Image palette, only the five most dominant colors are added. Colors from PostScript fills are not supported.
You can deselect the Eyedropper tool by pressing Esc.
You can move a color swatch by dragging a color swatch to a new position.
To remove a color from the Image palette Back to Top
To reset the Image palette Back to Top
To show or hide the Image palette Back to Top
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
