| • | To import a bitmap file |
| • | To save to a bitmap file |
| • | Windows Bitmap (BMP) technical notes |
The Windows bitmap (BMP) file format was developed as a standard for representing graphic images as bitmaps on the Windows operating system.
| 1 . | Click File |
| 2 . | Locate the folder in which the file is stored. |
| 3 . | Choose BMP - Windows bitmap (*.bmp; *.dib; *.rle) from the list box next to the File name box. |
| 4 . | Click the filename. |
| 5 . | Click Import. |
| 1 . | Click File |
| 2 . | Locate the folder in which you want to save the file. |
| 3 . | Choose BMP - Windows bitmap from the Save as type list box. |
| 4 . | Type a filename in the File name list box. |
| 5 . | Click Save. |
| • | You can import Windows Bitmap files conforming to the Windows and OS/2 BMP specifications. |
| • | Windows Bitmap files may be black-and-white, 16 colors, grayscale, paletted, or RGB color (24-bit), and print accordingly, depending on your printer. |
| • | Run-length encoding (RLE) compression may be used on all bitmaps, except RGB color (24-bit), and black-and-white bitmaps. |
| • | The resolution ranges from 72 to 300 dpi, or higher if you choose custom settings. |
| • | The maximum image size is 64,535 × 64,535 pixels. |
| • | Because raster images such as bitmaps are mapped pixel by pixel to the page, the resolution does not increase. Instead, your bitmap appears jagged, with an apparent loss of resolution. |
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
