| • | To update the list of fill packs in the Fill and Transparency pickers |
| • | To update the list of aliases in the Fill and Transparency pickers |
| • | To manage fills and transparencies |
The Fill and Transparency pickers let you manage the list of your local packs and aliases (links to local folders, network locations, and secondary storage devices). For example, you can rename the local packs or aliases, and you can remove aliases from the list. If an alias no longer works because the fill folder has been moved, you can browse to the new location to restore the link.
| 1 . | In the toolbox, click the Fill tool |
| 2 . | On the property bar, click one of the following buttons: |
| • | Fountain fill |
| • | Bitmap pattern fill |
| 3 . | Open the Fill picker or the Transparency picker on the property bar. |
| 4 . | Choose a fill pack from the Choose content source list box under User content. |
| 5 . | Click the Edit button |
Click Rename, and in the Rename Pack or Alias dialog box, type a name in the Name box.
Click Open folder location.
Click Open folder location. Select the folder that contains the pack in Windows Explorer, right-click it, and click Delete.
This action deletes the fill pack and removes it from the list in the Fill and Transparency pickers.
| • | Fountain fill |
| 4 . | Choose an alias from Choose content source list box. |
Click Browse, and navigate to the folder that contains the fills.
Click Remove.
| • | Fountain fill |
| 4 . | Perform an action from the following table. |
Right-click a thumbnail, and click Favorite.
Right-click a thumbnail, and click Properties. In the Properties dialog box, do any of the following:
This procedure applies only to bitmap patterns and fountain fills and transparencies.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
