Blur special effects
The blur special effects change the pixels of an image to soften them, smooth their edges, blend them, or create motion effects.
Tune blur Back to Top
The Tune blur effect (Effects Blur Tune blur) lets you apply any of four blurring effects, which are represented by thumbnails, to an image. You can adjust the blur effect and preview the image with softer or sharper focus while you are editing it. The Tune blur filter lets you improve image quality or create exciting visual effects.
Original
Tune blur
Directional smooth Back to Top
The Directional smooth effect (Effects Blur Directional smooth) smooths the regions of gradual change in an image while preserving edge detail and texture. You can use this filter to subtly blur the edges and surfaces of images without distorting the focus.
Original
Directional smooth
Gaussian blur Back to Top
The Gaussian blur (Effects Blur Gaussian blur) effect produces a hazy effect, blurring the focus of an image according to Gaussian distribution, which spreads the pixel information outward using bell-shaped curves. The effect can improve the quality of bitmaps with sharp edges. Move the Radius slider to adjust the intensity of the effect. The Gaussian Blur effect supports all color modes except Paletted and Black-and-White.
Original
Gaussian blur
Jaggy despeckle Back to Top
The Jaggy despeckle effect (Effects Blur Jaggy despeckle) scatters colors in an image, creating a soft, blurred effect with minimal distortion. It is most effective for removing the jagged edges that can appear in line art or high-contrast images. The Jaggy despeckle effect is also a preset lens type.
Original
Jaggy despeckle
Low pass Back to Top
The Low pass effect (Effects Blur Low pass) removes sharp edges and detail from an image, leaving smooth gradients and low-frequency areas. The higher the settings you specify, the more image detail is erased.
Original
Low pass
Motion blur Back to Top
The Motion blur effect (Effects Blur Motion blur) creates the illusion of movement in an image. You can specify the direction of movement.
Original
Motion blur
Radial blur Back to Top
The Radial blur effect (Effects Blur Radial blur) creates a blurring effect in an image that spins around or radiates outward from a center point that you specify.
Original
Radial blur
Bokeh blur Back to Top
The Bokeh blur effect (Effects Blur Bokeh blur) lets you control the amount of blur applied to the outside of an editable area and adjust the transition between the area in focus and the blurred area. For more information, see Applying the Bokeh Blur effect.
Original
Bokeh blur
Smooth Back to Top
The Smooth effect (Effects Blur Smooth) mutes the differences between adjacent pixels to smooth an image without losing detail. It is especially useful for removing the dithering that is created when you convert an image from the paletted mode to the RGB mode. The Smooth effect produces a more pronounced effect than the Soften effect. The Smooth effect is also a preset lens type.
Original
Smooth
Soften Back to Top
The Soften effect (Effects Blur Soften) smooths and tones down the harsh edges in an image without losing important image detail. The difference between the Smooth and Soften effects is subtle but is often apparent when images are viewed at high resolution. The Soften effect is also a preset lens type.
Original
Soften
Zoom Back to Top
The Zoom effect (Effects Blur Zoom) blurs image pixels outward from a center point. The pixels closest to the center point are the least blurry.
Original
Zoom
Smart blur Back to Top
The Smart blur effect (Effects Blur Smart blur) blurs an image but retains the edge detail. This effect is useful if you want to retain the sharp lines and edges, such as the ones that form the letters in text, when you export an image to a file format that would normally reduce the amount of detail. This effect is ideal for removing noise and artifacts from JPEG images.
Original
Smart blur
The Smart blur effect smooths the surfaces while keeping the edges sharp.
Some features described in the Help are not included in this version of the product, and are available only in CorelDRAW Graphics Suite 2018.
