Change and view object properties
You can rename an object and change its properties. When you create an object, it is given a default name, such as Object 2. If you have not specified settings, the default settings are applied to the object. In some programs, object properties are also known as layer options.
You can change the opacity of an object, choose a merge mode, and modify the way an object blends with underlying objects or with the background image. For more information about merge modes, see Merge modes.
You can view information about the object such as its name, opacity, size, and merge mode by pointing to the object in the image window.
To change the properties of an object
Back to Top
1 In the toolbox, click the Pick tool .
2 Select an object in the image window.
3 Control-click an object, and choose Object properties.
4 Click the General tab.
5 Type a new name in the Name box.
You can also
Change the opacity of an object
Move the Opacity slider.
Choose a merge mode
Choose a merge mode from the Merge mode list box.
Change the way an object blends with underlying objects or with the background
Modify settings in the Blend area.
You can also rename an object by double-clicking its name in the Objects inspector.
You can choose a merge mode for a group of objects from the Merge mode list box in the Objects inspector.
To view object information
Back to Top
Point to an object in the image window.
If an info tip doesn’t appear, click View Object Tips to enable the command.
