You can adjust the appearance of an object by changing the characteristics of its edges. You can blend the edges of an object with the background by feathering, defringing, and removing black and white edges. To emphasize a certain object in an image, you can sharpen its edges. You can also customize the object marquee.
Feathering softens the edges of an object by gradually increasing the transparency of the edge pixels. You can specify the width of the feathered section of the object and the transparency gradient you want to use.
The object on the right has been feathered to soften its edges.
An object created from an editable area sometimes includes stray pixels along its edges. This is apparent when the editable area is surrounded by pixels of a different brightness or color. Defringing replaces the color of the stray pixels with a color from the object so that the object blends with the background.
Removing black or white object edges
You can remove black or white edges from a feathered object by making pixels along the edges more transparent or more opaque.
Sharpening defines the edges of an object by making the edges crisp. You can do this by specifying the grayscale threshold for the pixels located along the object’s edges. The edges become sharper as the pixels below the threshold become transparent and the pixels within the threshold become opaque.
The object on the right has been sharpened to define its edges and make them more crisp.
Changing the appearance of the object marquee
You can customize the appearance of the object marquee by changing its color and threshold value. Changing the marquee threshold value modifies the location of the visual boundary of the active object. You can also change the color of the object marquee to make it more visible against the image background.
You can also hide the object marquee.
To feather the edges of an object non-destructively, select the object, click the Add Effect button in the Objects inspector (Window
Inspectors
Objects), click Blur, and then click Feather.
You can also feather the edges of an editable area by clicking the Feather mask button on the property bar.
When you change the threshold value of the object marquee, the area enclosed by the marquee changes, but the object itself does not change. Pixels that are not completely opaque can lie outside the marquee even though they are still part of the object.
