Custom brushes
You can create a custom brush by modifying brush attributes. Once you have created a custom brush, you can save it and use it again.
Nib properties
The shape of a brush is determined by the brush nib. The preset nib shapes can be modified or a nib can be created from an editable area and saved. The nib attributes you can adjust are
Transparency — lets you specify the
transparency level for the nib
Rotation/Direction — lets you specify the angle at which the nib is rotated. You can use a value between 0 and 360. When you enable pen bearing, this value determines the start angle of rotation. As you rotate the pen or stylus, values are added to the start angle of rotation to determine the overall rotation of the brush nib.
Flatness— lets you specify the amount by which the nib is flattened. The default value of 0 does not flatten the brush nib. When you enable pen tilt, the flatness value determines the starting flatness of the nib. As you tilt the pen, the nib flatness varies.
Elongation — lets you elongate the brush nib. You can use a value between 1 and 999 for the elongation distance. The default value of 0 has elongation turned off. The direction in which the brush nib is elongated is determined by the value in the
Rotation/Direction box as well as the bearing and rotation of your stylus. For example, a value of 0 in the
Rotation/Direction box elongates the brush nib straight up vertically. You can use only elongation or only flatness but not both at the same time.
Soft Edge — lets you specify the transparency and width of the edges of the nib
Stroke attributes
The stroke attributes you can modify are
Smoothing — lets you specify a value for the smoothing of the stroke when the mouse moves fast. A higher value results in a rounder curve.
Fade out — lets you specify the
intensity of the fade-out effect for the brushstroke. A higher value results in a shorter brushstroke, i.e., the brushstroke runs out of paint faster. A negative value results in a fade-in effect.
Dab attributes
The dab attributes you can adjust are
Number of dabs — lets you specify the number of dabs in a brushstroke
Spacing — lets you specify the amount of space between dabs along the length of the brushstroke. A value of 1 produces a solid line. A higher value separates the dabs in the brushstroke.
Spread — lets you specify the distance between dabs along the width of the brushstroke. A higher value results in a thicker brushstroke.
Hue — lets you specify the
hue variation in the brushstroke
Saturation — lets you specify the
saturation variation in the brushstroke
Lightness — lets you specify the lightness variation in the brushstroke
Brush texture
Loading a preset brush texture gives you additional design options. The texture attributes you can adjust are
Brush Texture — lets you specify how much of the texture is applied to the brushstroke
Edge texture — lets you specify how much of the texture is applied to the edges of the brushstroke. The
Edge Texture box is available only if the nib has a soft edge.
Bleed — lets you specify the extent to which brushstrokes become diluted throughout the stroke. If a
Sustain Color value is specified, traces of the paint remain throughout the brushstroke.
Sustain color — lets you specify the extent to which traces of the paint color appear in a brushstroke with a specified bleed value
Color variation
The color attributes you can modify are
Hue range — lets you specify the amount of
Hue speed — lets you specify how fast the hue value changes
Saturation range — lets you specify the amount of
Saturation speed — lets you specify how fast the saturation value changes
Lightness range — lets you specify the amount of lightness variation in the brushstroke
Lightness speed — lets you specify how fast the lightness value changes
To create a custom brush
In the toolbox, click the
Paint tool
Open the
Brush picker on the property bar, choose a brush category, and then choose a brush.
Choose a preset brush in the
Brush type list box on the property bar.
4
In the
Brush Settings inspector, move the
Size slider.
If the
Brush Settings inspector is not open, click
Window
Inspectors
Brush Settings.
5
In the
Brush Settings inspector, click the roll-down arrow on any of the following bars, and specify values for any attributes:
Add a custom nib to the Nib shape picker
Click the Nib options button  on the Nib properties bar, and click Add current nib.
Click the flyout arrow  on the Brush Settings inspector, and click Save brush. In the Save brush dialog box, type a filename.
To create a brush nib from an editable area
Paint tool
Open the
4
In the
Nib options button
on the
Nib properties bar.
If the
Window
Inspectors
Brush Settings.
5
Click
Create from contents of mask.
6
Type a value in the
Nib size box.
To load a preset brush texture
Paint tool
Open the
In the
Load texture button
on the
Brush texture bar.
If the
Window
Inspectors
Brush Settings.
4
Choose a texture, or click
More to locate the texture file you want.
5
Double-click the filename.
6
In the
Brush Settings inspector, click the roll-down arrow on the
Brush texture bar, and type a value from 0 to 100 in any of the following boxes:
Brush texture — lets you adjust the amount of texture applied to a brushstroke
Edge texture — lets you adjust the amount of texture applied to the edge of a brushstroke
