Transform editable areas
You can transform an editable area of a mask by rotating, scaling, sizing, skewing, distorting, or applying perspective to it. Before you transform an editable area, choose whether the transformations you apply affect the mask form or the pixels in the masked area.
Include mask pixels in (left) or exclude mask pixels from (right) transformations.
You can perform multiple transformations before applying them. For example, you can scale and rotate the editable area of a mask and then commit the changes. If an editable area is floating above the image, it is automatically merged with the underlying image when it is transformed.
Transformation
Description
Rotating
Lets you rotate an editable area
Scaling
Lets you size an editable area to a percentage of its original size
Sizing
Lets you change the width and height of an editable area
Skewing
Lets you slant an editable area in one direction. One side remains stationary while the other sides move in the specified direction. All opposite sides maintain a parallel relation to each other.
Distorting
Lets you stretch or shrink an editable area disproportionately
Applying perspective
Lets you give a three-dimensional appearance to an editable area
To include the pixels of an editable area in transformations
Back to Top
1 In the toolbox, click the Mask transform tool .
2 Click the Transform pixels button on the property bar.
3 Transform the editable area by rotating, scaling, sizing, flipping, skewing, distorting, or applying perspective to it.
The Transform pixels button lets you include mask pixels in or exclude mask pixels from transformations. Make sure you choose the mode you want before transforming an editable area. Clicking the button after performing one or more transformations commits the changes.
To rotate an editable area
Back to Top
If you want to include the pixels of the editable area in the transformation, make sure the Transform pixels button on the property bar appears pressed.
2 Click the Rotate button on the property bar.
If you want to change the center of rotation of the editable area, drag the center of rotation to a new position within the editable area.
3 Drag a corner handle of the mask marquee.
4 Double-click in the editable area.
You can rotate an editable area by a specific angle by typing a value in the Angle of rotation box on the property bar and clicking Apply.
You can change the center of rotation, also known as a pivot point, by typing values in the Center of rotation boxes on the property bar and clicking Apply.
To scale an editable area
Back to Top
2 Click the Scale button on the property bar.
You can also
Scale an editable area with precision
On the property bar, type percentage values in the Scale boxes and click Apply.
Scale an editable area while preserving the ratio of width and height
Click the Maintain ratio button on the property bar.
Scale an editable area from the center
Hold down Shift as you drag a corner handle.
To size an editable area
Back to Top
2 Click the Position and size button on the property bar.
3 Drag a middle handle of the mask marquee.
If you want to size the editable area proportionally, drag a corner handle of the mask marquee.
You can also
Size an editable area with precision
On the property bar, type values in the Size boxes and click Apply.
Size an editable area from the center
Hold down Shift as you drag a center transformation handle. The change in size occurs in two opposite directions.
Size an editable area in 100 percent increments
Hold down Command as you drag a transformation handle.
To flip an editable area
Back to Top
3 Drag a center handle of the mask marquee across the editable area and past the opposite center handle.
You can flip an editable area symmetrically by holding down Command and dragging a middle handle across the editable area and past the opposite middle handle.
To skew an editable area
Back to Top
2 Click the Skew button on the property bar.
You can also skew an editable area by typing values in the Skew angle boxes on the property bar and clicking Apply.
Before applying the transformation, you can return an editable area to its original size by pressing Esc.
To distort an editable area
Back to Top
2 Click the Distort button on the property bar.
3 Drag a transformation handle of the mask marquee.
You can also set the Mask transform tool to the Distort mode by clicking in the editable area until the handles you can use to distort the editable area appear.
Before applying the transformation, you can return the editable area to its original size by pressing Esc.
To apply perspective to an editable area
Back to Top
2 Click the Perspective button on the property bar.
You can also set the Mask transform tool to the Perspective mode by clicking in the editable area until the transformation handles appear.
