Adjust color and tone by using brush effects
You can adjust the brightness, contrast, hue or saturation in part of an image by applying brush effects. For example, if you want to lighten one object in a photo, you can use the Brightness tool to lighten the area you want without affecting the surrounding area.
You can use preset brushes or create a custom brush. For more information, see Custom brushes.
To adjust image color and tone by using brush effects
Select an
object or the background image.
In the toolbox, click the
Effect tool
On the property bar, open the
Brush picker, and click one of the following brush categories:
Brightness — brightens or darkens the image
Contrast
— increases or decreases the
contrast
Hue
— shifts all hues along the color wheel by the number of degrees that you specify in the
Amount box
Hue replacer
— retains the
brightness and
saturation of the original colors, but replaces all
hues with the current paint color
Sponge
— saturates or desaturates the colors
Tint
— uses the current paint color to tint the image
Dodge/Burn
— brightens (overexposes) or darkens (underexposes) the image. You can choose a Dodge or Burn preset brush from the
Brush type list box.
4
Choose a preset brush from the
Brush picker.
If you want to customize the brush, specify the settings you want on the property bar.
5
Drag in the image window.
Increase the effect of a brush tool without clicking multiple times
In the Brush Settings docker, click the Cumulative button  on the Stroke attributes bar. This option is available for only some of the Effect tools. If the Brush Settings docker is not open, click Window Dockers Brush Settings.
Apply the effect to both an object and the background simultaneously
In the Brush Settings docker, click the Merge source button  on the Dab attributes bar. This option is available only when the Cumulative button is disabled.
