Configure GPUs
If your system has multiple available graphics processing units (GPUs), you can select which one CorelDRAW Graphics Suite uses for various processing tasks.
CorelDRAW Graphics Suite utilizes GPU hardware acceleration in the following areas:
Display – provides fluid panning, zooming, and screen rendering
Effects – lets you apply bitmap effects as lenses, providing greater precision and design freedom
Art Styles – these presets use AI technology to modify an image or object, producing a stylized version while preserving the original content
Resampling – AI-powered upsampling is used to enlarge images and trace bitmaps, resulting in clean edges, sharpness, and fine details
JPEG Artifact Removal – advanced machine-learning technology is used to remove JPEG compression artifacts, restoring both color and detail in images
To configure GPUs
Back to Top
1 Click Tools Options Global.
By default, the Use hardware acceleration check box is enabled.
2 Choose a GPU from the Use hardware acceleration list box.
3 Enable or disable the check boxes that correspond with the areas of hardware acceleration that you want to turn on or off:
Display
Effects
Art Styles
Resampling
If the selected GPU is not normally used for display, CorelDRAW Graphics Suite will continue to use the OS-designated GPU for display to maintain optimal performance. The selected GPU will be used for all other hardware acceleration options.
Changes made to the GPU configuration may require an application restart.
