Erase image areas
You can edit images and objects by erasing areas. For example, you can erase part of an object to change its shape or reveal more of the layer below. You can also erase background areas of the image, or erase part of the last action applied to the image.
The Eraser tool was used to erase background areas and reveal the secondary color.
The background was first converted to an object, and then the Eraser tool was used to erase background areas, making them fully transparent.
The tools used to erase have many of the same settings as brushes, which means you can control the size, shape and transparency to create unique effects. For example, you can apply a bitmap fill to the entire image, increase the transparency value of the eraser tool, and create a superimposed effect by partially erasing the fill (the last action performed). You can also erase image areas based on color. The secondary color replaces the main color you erase.
To erase image areas
Back to Top
1 Do one of the following:
Select an object.
Select the background layer.
2 Click the Eraser tool .
3 Specify the settings you want on the property bar.
4 Drag across the area you want to erase.
Erasing parts of an object reveals the object below or the background.
Erasing the background reveals the secondary color. To make the erased areas fully transparent, first create an object from the background by clicking Object Create From Background.
To maintain the shape of an object, enable the Lock transparency button on the Objects docker. If the Objects docker is not open, click Window Dockers Objects.
To adjust the transparency interactively, hold down Alt, and click in the image window without releasing the mouse button to display a transparency slider.
To adjust the feathering interactively, hold down Ctrl + Alt, and click in the image window without releasing the mouse button to display a feathering slider.
To erase with symmetrical patterns, click Window Toolbars Symmetry bar, and choose the settings you want on the Symmetry bar before dragging in the image window. For more information on the Symmetry bar, see To paint symmetrical patterns.
To erase the last action applied to an image
Back to Top
1 In the toolbox, click the Undo Brush tool .
2 Specify the settings you want on the property bar.
3 Drag across the area you want to erase.
If you want to erase the last action completely, click the Undo button on the standard toolbar. For more information about undoing, see Undo and redo.
You can also erase the last action applied to an object, but you must use the Eraser tool to erase the object itself.
To replace the main color with the secondary color
Back to Top
1 In the toolbox, click the Replace Color Brush tool .
2 On the property bar, choose a nib shape from the Nib shape picker.
3 Type a value in the Tolerance box to specify the color tolerance based on color similarity.
4 In the color control area of the toolbox, double-click the Main color swatch, and choose a color.
5 Drag in the image window.
You can select a main color from the image by clicking the Eyedropper tool , and clicking a color in the image window. The color you select displays in the Main color swatch.
You can quickly choose a square or round brush shape by clicking the Round nib button or the Square nib button on the property bar.
