Guidelines
Guidelines are vertical or horizontal lines that you can add anywhere in the image window to help you measure, align, and position image components. The guidelines use the same units of measure as the rulers. When you save an image in the Corel PHOTO-PAINT application, the guidelines are saved too.
You can display or hide the guidelines. You can also add, remove, move, and lock guidelines in the image window. You can add angled guidelines and rotate existing guidelines.
You can have objects and editable areas snap to guidelines, so that when you move an object or editable area to a guideline, the object or editable area automatically aligns to that guideline. You can set the sensitivity of this feature so that the object or editable area snaps when you move within a specific number of pixels of a guideline.
You can change the color and line style of the guidelines to make them stand out against the image background. By default, when you select a guideline, it turns red. When you deselect a guideline, it turns blue.
To display or hide the guidelines
Click
View
Guidelines.
A check mark beside the menu command indicates that the
guidelines are displayed.
You can also display or hide the guidelines by clicking Window
Dockers
Guidelines and clicking the Show guidelines button
Guidelines displayed
To add a horizontal or vertical guideline
Click
Window
Dockers
Guidelines.
Choose one of the following options from the
Guideline type list box:
Specify the location of the guideline in the
x or
y box.
You can also add a guideline by dragging from the horizontal or vertical ruler to the image window.
To add an angled guideline
Click
Window
Dockers
Guidelines.
Choose
Angled from the
Guideline type list box.
x and
y boxes.
4
Type a value in
Angle of rotation box.
To remove a guideline
Click
Window
Dockers
Guidelines.
Choose a guideline from the list.
You can choose multiple guidelines by holding down
Ctrl as you click.
Click the
Delete guideline button
You can also remove individual guidelines by dragging them off the image window.
To move a guideline
In the toolbox, click the
Pick tool
Drag a
guideline to a new position in the image window.
You can also move a guideline by nudging it.
To move a guideline by specifying x and y coordinates, click Window
Dockers
Guidelines. Select the guideline, type values in the x and y boxes, and click Modify.
To rotate a guideline
Pick tool
Perform a task from the following table.
Click the guideline twice, and then rotate the guideline when rotation handles  appear.
You can also rotate a guideline by choosing Angled from the Guideline type list box, typing a value in the Angle of rotation box, and clicking Modify.
Rotate multiple guidelines
Hold down Shift, select the guidelines, click a selected guideline again, and rotate the guidelines when the rotation handles appear.
The center of rotation is determined by the last guideline you selected.
Rotate a guideline by a specific value
Click the guideline twice to display the rotation handles, and type a value in the Angle of rotation box on the property bar.
You can also rotate multiple guidelines by a specific value.
Rotate a guideline in 15º increments
Click the guideline twice to display the rotation handles, hold down Ctrl, and rotate the guideline.
You can also rotate multiple guidelines in 15º increments.
Drag the guideline’s center of rotation to a new location or type a value in the Center of rotation box on the property bar.
To lock or unlock the guidelines
Click
View
Lock guidelines.
A check mark displays beside the menu command to indicate the
guideline is locked.
You can also lock a guideline by clicking Window
Dockers
Guidelines and clicking the Lock guideline button
To have objects and editable areas snap to the guidelines
Click
View
Snap to
Guidelines.
You can also set objects and editable areas to snap to a guideline by clicking Window
Dockers
Guidelines and clicking the Snap to guideline button
To set the snap sensitivity of the guidelines
Click
Tools
Options
Corel PHOTO-PAINT.
Type a value in the
Guideline snap tolerance (pixels) box.
To set the line style and color of a guideline
Click
Window
Dockers
Guidelines.
Open the
Guideline color picker, and choose a color.
Open the
Guideline style picker, and choose a line style.
Changing the line style or color affects all existing guidelines and any subsequent guidelines that you add.
