Kern, shift, and rotate text
You can kern text, which lets you adjust the space between individual characters within a range of selected text. Kerning refers to the repositioning of two characters to balance the optical space between them. For example, kerning is often used to decrease the space in character pairs such as AW, WA, VA, or TA. Such character pairs are known as "kerning pairs." Kerning increases readability and makes letters appear balanced and proportional, especially at larger font sizes.
You can modify the appearance of text by shifting the characters vertically or horizontally, which changes the position of the selected characters relative to the surrounding characters. You can also rotate characters by specifying an angle of rotation.
To kern text
Back to Top
1 Using the Text tool , select the text.
2 Click Object Text Text.
3 In the Text docker, type a value in the Range kerning box.
To shift characters
Back to Top
3 In the Text docker, click the arrow button to display the additional character options.
4 Perform a task from the following table.
To
Do the following
Shift characters horizontally
Type a value in the Horizontal character offset box.
Shift characters vertically
Type a value in the Vertical character offset box.
Positive horizontal values move the characters to the right; negative horizontal values move them to the left. Positive vertical values move the characters up; negative vertical values move the characters down.
To rotate text
Back to Top
4 Type a value in the Character angle box.
