Lighting effects
You can add light sources to an RGB or grayscale image to create the illusion of spotlights, floodlights, or sunlight. You can specify the type and number of light sources, the intensity of the light, and the color of the light. You can also create embossed reliefs by applying a preset or modifying color channel information. You can use a preset light and texture style, or you can customize a preset style and save it in the preset list.
To apply a lighting effect
Click
Effects
Camera
Lighting effects.
This applies the effect destructively. To apply the effect non-destructively, click
Window
Dockers
Effects, then click the
Add effect button
, and choose
Camera
Lighting effects.
Click the
Light source tab
Enable the
Spotlight option in the
Type area.
4
In the preview window, drag the
Light source selector
to set the position and direction for the light.
5
Type a value in the
Angle box to set the angle of the light relative to the image.
6
Move any of the following sliders:
Brightness — lets you set the intensity of the light source
Cone size — lets you set the width of the light beam. Higher values produce a wider, more diffused light beam.
Edge — lets you set the diffusion of the light along the edge of the beam
Opacity — lets you set the density of the light
7
Click the
Atmosphere tab
, and move the
Brightness slider to adjust the
brightness of the entire image.
Change the color of the light
Click the Color picker, and choose a color swatch.
Add a light with the same properties as the last light applied
Click the Add light button  .
Delete the last light applied
Click the Delete light button  .
Hide/Reveal the Light source selector
Click the Hide/Reveal Light source button  .
Add three-dimensional texture using a preset
Choose a preset that adds texture to the image from the Presets list box, and click the Image texture tab  to set the properties you want.
Add three-dimensional texture using color channels
Click the Image texture tab  , choose a color channel from the Channels list box, and modify the settings you want.
