Save movies
You can save a movie before or after you add the background and objects; however, when you save a movie as a an animated GIF or to the AVI format, objects are automatically combined with the background in every frame and are no longer editable.
If you want use a movie on a webpage, save it to the animated GIF file format. When you save a movie to this format, you must convert it to an 8-bit palette, consisting of 256 colors. For information on converting a 24-bit image to 8-bit Paletted color mode, see Black-and-white color mode.
When you save a movie to animated GIF format, you can make a color transparent, which lets you see the background of a webpage through the movie. You can also specify the number of times your movie replays.
To save a movie
Click
File
Save As.
Choose the folder where you want to save the file.
From the
Save as type list box, choose a file format.
4
Type a filename in the
File name box, and click
Save.
To save a movie as an animated GIF
Click
File
Save As.
File name box.
4
Choose
GIF - GIF animation from the
Save as type list box, and click
Save.
5
In the
Convert to paletted dialog box, modify the settings you want, and then click
OK.
6
In the
GIF 89 Animation Options dialog box, click the
Frame Settings tab.
7
Enable one of the following options in the
Palette area:
Use Global — uses the same color palette for all frames
Use Local — uses a different color palette for each frame
8
Type a value in the
Frame Delay box to specify the length of time between frames.
9
Click one of the following buttons:
Apply Changed Only — applies only the frame settings that have changed
Apply All — applies all frame settings
Choose a color to appear transparent in the movie
Enable the Image Color option, and click Select Color. In the Select Color dialog box, choose a color and click OK.
Refresh the image after each frame is loaded
Enable the Interlace Rows check box.
Specify the number of pixels a frame is offset
Type values in the X and Y boxes to offset the current frame from the top left corner of the page. Type values in the dX and dY boxes to offset each successive frame from the preceding frame.
Specify how the previous frame disappears
Choose an option from the How To Dispose list box. To make a transparent background, choose Replace With Background.
Play the animation repeatedly
Click the File Settings tab, enable the Loop Frames check box, and enable an option in the Frame Repetition area.
Enable the Automatic check box or type values in the Width and Height boxes to set the background size manually.
Save only the pixels that differ from the first frame
Enable the Save Difference Between Frames Only check box.
Changes are applied only to selected frames. Select all frames in the left window to apply changes to all frames.
When you save a movie as an animated GIF, objects are automatically combined with the background of each frame. This means that you can no longer edit the objects separately from the image.
