TIFF
The Tagged Image File format (TIFF) is a raster format designed as a standard. Almost every graphics application can read and write TIFF files. TIFF supports various color modes and bit depths.
You can open or import TIFF files in Corel PHOTO-PAINT. For more information about opening or importing files, see Open images or Import files.
To export a TIFF file
Click
File
Export.
Locate the folder in which you want to save the file.
Choose
TIF - TIFF bitmap from the
Save as type list box.
4
Type a filename in the
File name list box.
TIFF technical notes
When importing a TIFF that contains multiple pages, you can choose the individual pages that you want to import.
Masks are not exported in 1-bit black-and-white, 16-bit grayscale, or 48-bit RGB files.
Black-and-white, color, and grayscale TIFF files up to and including the 6.0 specification can be imported and exported.
TIFF files compressed using JPEG, ZIP, CCITT, Packbits 32773, or LZW compression can also be imported. However, you may notice additional loading time with these files because the program decodes the file compression.
