Windows Bitmap (BMP)
The Windows bitmap (BMP) file format was developed as a standard for representing graphic images as bitmaps on the Windows operating system.
To import a bitmap file
Click
File
Import.
Locate the folder in which the file is stored.
Choose
BMP - Windows bitmap (*.bmp; *.dib; *.rle) from the list box next to the
File name box.
To save to a bitmap file
Click
File
Save as.
Locate the folder in which you want to save the file.
Choose
BMP - Windows bitmap from the
Save as type list box.
4
Type a filename in the
File name list box.
Windows Bitmap (BMP) technical notes
Importing a BMP file
You can import Windows Bitmap files conforming to the Windows and OS/2 BMP specifications.
Run-length encoding (RLE) compression may be used on all bitmaps, except RGB color (24-bit), and black-and-white bitmaps.
The resolution ranges from 72 to 300
dpi, or higher if you choose custom settings.
The maximum image size is 64,535 × 64,535
pixels.
Exporting a BMP file
Because raster images such as
bitmaps are mapped
pixel by pixel to the page, the
resolution does not increase. Instead, your bitmap appears jagged, with an apparent loss of resolution.
