It is important that the colors represented on your monitor are reasonably accurate and meaningful. For example, red should really look red and not like a shade of orange or purple, and 50% gray shouldn’t look like light gray or dark gray.
In Corel PaintShop Pro, you can use a wizard that walks you through the process of calibrating your monitor so it displays accurate colors. At the end of the process, you can save a color profile for your monitor and apply the adjustments.
Edit workspace
Choose File Color Management Monitor Calibration. |
![*](images/tip.gif)
You can also calibrate red, green, and blue tones for your monitor by marking the Advanced options check box when it appears on a wizard page.
You can clear the calibration settings for a wizard page by clicking Reset.
