In Corel PaintShop Pro, you can use the following color depths:
• | 2 colors |
• | 16 colors |
• | 256 colors |
• | 8-bit per channel RGB |
• | 8-bit per channel Grey |
• | 16-bit per channel RGB |
• | 16-bit per channel Grey |
Before you change the color depth of your image, consider the following:
• | Many effect and correction commands work on higher color depth images only. After you finish working on an image, you can decrease its color depth and save it in another format. |
