Using the Learning Center palette
The Learning Center palette contains helpful information about Corel PaintShop Pro tasks, commands, and tools to help first‑time users as well as experienced users get their work done faster. You can use the Learning Center in one of two ways: from the Home page, navigate through the task-based workflow, or simply click a tool in the Tools toolbar and follow the corresponding instructions that appear in the Learning Center palette.
Each task appearing on the Home page has its own topics with instructions that describe its related tools or commands. You can click a given topic to access a related tool or command. In this way, you can perform a task as you learn about it. You can also access the Help from the Learning Center palette to obtain additional information about a task.
From the Learning Center Home page, click a task, and then click a topic.
To display or hide the Learning Center palette Back to Top
Edit workspace
The Learning Center palette is displayed by default. It appears along the right side of the Edit workspace.
To use the Learning Center palette Back to Top
Edit workspace
Some tasks and commands are not available unless an image is open.
