You can use Corel PaintShop Pro to view the color depth information for images. You can also check the color depth of a monitor to ensure it supports the color depth of the images with which you are working.
The number of colors actually used in an image is usually less than the color depth. For example, a 16 million-color image is capable of displaying that many colors, but may only use 50,000 colors. You can use Corel PaintShop Pro to view the number of colors used in an image or layer.
Edit workspace
Choose Image Image Information. |
![*](images/tip.gif)
You can also view the color depth information on the Status bar. The color depth information appears after the two numbers that display the pixel dimensions of the image.
You can also view color depth information on Overview palette by pressing F9, clicking the Info tab, and viewing the Color Depth field.
Edit workspace
Choose Help About PaintShop Pro. |
Edit workspace
Choose Image Count Image Colors. |
Edit workspace
Choose Layers Count Layer Colors. |
