If you are preparing professional quality digital images, you can enable or disable color management settings. Additionally, every RGB image in Corel PaintShop Pro has a profile associated with it. By default, these advanced color settings are enabled, allowing the application to make use of a consistent color working space. You can define advanced features for color working spaces and profiles. For example, you can set a CMYK profile that determines how CMYK images are processed when you split or combine CMYK channels, or when you output to a CMYK TIF file.
Edit workspace
Choose File Color Management Color Management. |
Choose the Basic color management option to access controls for your monitor and printer. |
4
In the Monitor Profile drop-list, choose the monitor profile you want to use. |
5
In the Printer Profile drop-list, choose the printer profile you want to use. |
6
In the Rendering Intent drop-list, choose the setting that matches your intended output. |
![*](images/note.gif)
Only valid and correctly installed profiles appear in the profile lists.
If you have Administrator privileges for your computer, the profile you save becomes the active monitor profile. If you are a restricted user, you must contact your System Administrator to install the profile.
![*](images/tip.gif)
You can set your printer to simulate a printing press by choosing the Proofing option, choosing a device in the Emulated Device Profile drop-list, and choosing the appropriate option in the Rendering Intent drop-list.
Edit workspace
Choose File Color Management Color Working Space. |
In the Color Working Space drop-list, choose a color space. |
4
In the CMYK Profile drop-list, choose a profile to be used for the CMYK-related operations in the application. |
