Working with color sets
Color sets are collections of colors that help you organize and store colors. Some color sets are organized by both name and color relationship. Corel Painter provides several color sets — Painter Colors, macOS and Windows system palettes, and the PANTONE MATCHING SYSTEM are a few. You can open any of the available color sets, choose a color from the color set, and then apply it to a brushstroke. You can open multiple color sets at a time.
In addition, you can import a color set to access additional colors. For example, you can import a color set that you created in a previous version of Corel Painter.
If you need to find a specific color in a color set, you can search for the color by name or have Corel Painter find the color that comes closest to matching the current color.
Color Sets panel
To display the Color Sets panel
Choose
Window
Color Panels
Color Sets.
To open a color set
In the
Color Set Libraries panel, click the Color Set Libraries options button
, and choose
Color Set Libraries, and choose a color set from the list.
To choose a color from a color set
In the
Color Set Libraries panel, click a color.
To import a color set
In the
Import Color Set button
In the
Select Color Set dialog box, click the
Color Sets folder, choose a color set, and click
Open.
To find a color in a color set
In the
Search for Color button
In the
Find Color dialog box, do one of the following:
Enable the
By name option, and type a name in the box.
Enable
Closest to current color.
4
Click
OK when the desired color is found.
If the color set is visible, Corel Painter surrounds the found color with a selection frame.
If you search for a color by name, but a color with that name is not found, the
OK button is not available (it is grayed out).
