Captured dab controls
The Captured panel displays captured dab libraries and controls for changing the appearance of any brush. You can choose a captured dab, apply a dab effect and adjust its strength, and then capture the brush settings as a new dab in your library. You can also edit a captured dab. For information about creating brush dabs, see Creating and managing brush dabs.
To display the Captured panel
Choose
Window
Brush Control Panels
Brush Shape
Captured.
To choose a captured dab
In the
Captured panel, click a captured dab icon.
To edit a captured dab
In the
Captured panel, right-click a captured dab icon, and choose
Check Out Captured Dab.
In the Brush Selector, choose a brush variant, and then make any changes you want to the dab shape.
When you save the edited captured dab, it will be named after the currently selected brush variant.
In the toolbox, click the
Rectangular Selection tool
, and make a rectangular selection of the dab shape.
4
In the
Captured panel, click the
Capture Dab button.
The edited captured dab is added to the active captured dab library.
5
Click
File
Close and choose
Don’t Save to check the captured dab back into the library.
To apply a dab effect
In the
Dab Effects list box and choose one of the following options:
Feather — softens the edges of the brushstroke
Threshold — removes pixels from the brushstroke that are below the specified opacity strength
Blur — softens the brushstroke by smoothing the pixels and edges
Dilate — expands the pixels and edges of the brushstroke
Erode — contracts the pixels and edges of the brushstroke
Adjust the
Strength slider to determine the percentage of applied dab effect.
You can restore the brush variant to its default state by clicking the Reset Tool button
on the property bar.
To choose a captured dab library
In the
Manage Libraries flyout button
Captured Dab Libraries, and then choose one of the following options:
To modify the display of the Captured panel
In the
, choose
Captured Dab Library View, and then choose one of the following options:
To manage captured dab libraries
In the
Captured panel, perform a task from the following table.
Create a new captured dab library
Click the Manage Libraries flyout button  , and choose New Captured Dab Library. In the New Library dialog box, type a name in the Save As box, and click OK.
Import a captured dab library
Click the Manage Libraries flyout button  , and choose Import Captured Dab Library. In the Import Library dialog box, choose a captured dab library file, and click Open.
Export a captured dab library
Click the Manage Libraries flyout button  , and choose Export Captured Dab Library. In the Choose Library dialog box, select a captured dab library from the Library list box, and click OK. Type a name in the Save As box, choose a location from the Where box, and then click Save.
Remove a captured dab library
Click the Manage Libraries flyout button  , and choose Remove Captured Dab Library. In the Choose Library dialog box, select a library Library list box, and click OK
Restore the default captured dab library
Click the Manage Libraries flyout button  , and choose Restore Default Captured Dab Library.
Click the Manage Libraries flyout button  , and choose Show All Hidden Items.
