You can change the appearance of a document by assigning a new color profile. A color profile contains the data that the color management system requires to translate colors from one color space to another. The default color profile for Corel Painter is sRGB IEC61966-2-1 noBPC, but you can choose from a list of Standard ICC color profiles.
When you assign a new profile, the color values, or numbers, in the document do not change. When you enable color management and display a document, the colors in the document represent an interpretation of the assigned color profile. For more information, see Should I assign or convert color profiles?
You can also remove an assigned color profile from a document. In other words, color management is no longer applied to the document. The color values are retained, however.
If you have color profiles installed on your computer, Corel Painter includes them in the list of available color profiles.
You can also assign a color profile from the Navigator panel by clicking the Open Navigator Settings button , clicking Color Management, and choosing Assign Profile.
